cigar_stub
- Joined
- Jun 30, 2007
- 88
I have a 2002 Yamaha 115hp outboard on a 19' center console. The current prop is a 13x19 K (that's what I can read from the prop itself). My Seloc manual states the test prop for this motor was a Kent Moore Part #YB1624. I assume that means a 16" 24 degree pitch and I also assume the current prop is 13" with a 19 degree pitch. I have very slow takeoff from dead stop and with just me in the boat, once I'm up on plane which also takes longer than I think it should, I run about 33 mph at 5500 rpm which is the recommended top end.
I want to order a second prop to both see if I can improve the performance and to have a spare. Any thoughts about the current prop vs the factory test size? Also, any suggestions on what I should purchase to improve the hole shot? I was thinking of getting the smart tabs to improve the time needed to get on plane, but thought a different prop might help as well
Thanks in advance for any help/suggestions.
