Re: Selecting Transom Strap
I will submit that every boat on a trailer shifts a lot more than most people suspect.
Brake firmly and the boat will come up tight against the Bow stop.
Accelerate briskly and it will shift back an inch.
You always end the journey by braking so you think the boat stayed forward the whole trip when it didn't.
A pair of 2500# straps will be more than sufficient for your boat.
If you hit a huge bump the straps will be lifting the 800# trailer up to the boat, not holding the 3000# boat down.
In a Major Collision, only luck is going to keep the boat on the trailer no matter how it is attached.
Be sure to always insert the hook from the same side the strap came from, not the back side that looks cleaner.
Otherwise it will fall out at the first bump that gives it any slack.
