ssportsmfg
- Joined
- Oct 7, 2014
- 42
I have been trying to solve a rough idle problem and tune this motor up.
OK all you knowledgeable mechanics on here.....I have a Johnson 2001 50 2 cyl, 2 cycle. Model J50PL SIB
The Seloc book on tuning up this motor and syncing the spark advance and carb states the following.
For ALL models 1994 and later the spark advance rod length is determined only by the charging system that if it is 12 amp length should be 2.5" and 4 amp length should be 2"
Mine is currently set at 2 5/8" exactly.....which is listed as the length in the paragraph above but does not list my model or year.
I also looked up my motor and it is listed as 6 amp, which matches neither of the settings the book says the charging system will be. What am I missing here?
If I set the rod to 2.5 inches will that not advance the spark more than a 2 5/8" length and possibly damage the motor from to far advanced spark? Or does it matter? What is the reason for these exact lengths?
I have to admit I don't understand the setup's on these outboards at all. I have already figured out that the idle is set not with the carbs buy by the spark advance setting.
So far on this motor I have de-carboned, checked compression 145 and 140 top and bottom, checked the plug wires 000.1 resistance on both, and my sperry digital meter bounces between 000.0 and 000.1 with probes touching so my plug wires seem to be fine, no cuts or bleeding (watched at night) Strong spark.
Help with the correct spark advance rod length would be greatly appreciated, trying to do this myself, but with conflicting info that I am finding, I am not sure how to proceed.
Thanks!
Thanks!
