seloc riser vs mercruiser riser
yomamaho
Hey guys, could you tell me the difference between the 2 risers? Besides price i heard that factory parts sometimes don't last as long. Would i need anything different to install the seloc riser to my manifold or is it identical? Is it worth getting aluminum? The riser i'm replacing is 807988a03
Bt Doctur
Re: seloc riser vs mercruiser riser
Didnt know Seloc sold parts, but without knowing the engine type and drive , I cant answer that.
superbenk
You mean Sierra instead of Solec? Solec makes service manuals.
joncrisler
Sierra and GLM both make risers, manifolds and spacers. I have had good luck with both, and iboats.com I believe carries them. The parts are functionally and mechanically identical down to the bolts and gaskets- i.e. you can use either Merc, Sierra or GLM gaskets on any of the above parts. I would NOT get aluminum unless you have a closed cooling system.
yomamaho
Sorry guys meant osco. kids keep me busy.
Fishermark
Osco makes good stuff. Just be sure to use the graphite (black/grey) gasket, and not the green paper one.
rick3452
Yes.. Go out and buy the OEM Gaskets for Manifold & Risers, Osco and Barr are USA made..
