Sending unit
stemar
Hello and Happy new year,<br />I bought from overtons water pressure gauge but they don't sell the sending unit that attaches to the engine. Can you please tell me a site where I can order it.<br />Thanks
stemar
Re: Sending unit
Thanks John<br />I can't find it on teleflex site, I think you can not order through teleflex direct.<br />Thanks
Re: Sending unit
there Is No Sending unit.....<br />you just need to tap into the cooling system,+ then run a small plastic line to the gauge....
stemar
Re: Sending unit
Bondo<br />Don't you need the sending unit so you can attach it to the engine and then wire it to the gauge??
D
DJ
Guest
Re: Sending unit
stemar,<br /><br />If you have a water pressure guage, there is no sending unit. Most use a plastic or nylon tubing "tee" that splices into the telltale line.
stemar
Re: Sending unit
Sorry guys,<br />But If I understand well although I have the gauge I don't need the sendimg unit and instead I can use some other ways to make it work. I have 1989 Mariner 90 HP.<br />Thnaks again
D
DJ
Guest
Re: Sending unit
stemar,<br /><br />All you need is some tubing and a "tee". <br /><br />The tuibing inside diameter should be the same size as the outside diameter of the nipple on the back of the guage. <br /><br />Then, you will need a 3-way tee to tie into the telltale line on the engine. An automotive vacuum line tee will work fine for this as well as automotive vacuum hose.<br /><br />The tell tale, on the back of the engine has a discharge line going from the cylinder head to the outlet. Simply cut and splice the tee into that line. The open end of the tee goes to the guage.
stemar
Re: Sending unit
Thanks a lot djohns19 <br />OK I understand this. Do I need to connect it to the electrical wires as well??<br />Thanks<br /> again
snapperbait
Re: Sending unit
Only need to hook up electric if you want the light inside the gauge to work at night when you turn on the navigation lights... ;)
stemar
Re: Sending unit
Thanks a lot guys,<br />Now I fully understand what I have to do.<br />IF you please can you be more specific where exactly the tell tale is located so I DO NOT splice anything else!!! :confused: A s I mentioned before my engine is 1989 Mariner 90HP.<br />Thnaks again
93evinrude
Re: Sending unit
I believe you will find the info you require in the link from my previous post.Open the file on water pressure gauge installation....
