1970Thunderbird
- Joined
- Dec 24, 2009
- 111
Hello again, friends.
My engine lifting eye arrived today, so I immediately tried lifting the power head from the lower unit. I'd previously disconnected the 6 bolts that hold it to the lower unit, as well as wiring, hoses and other parts. I also removed the nuts from the two bolts up front, beneath the cowl that also hold the power head to the lower unit.
I started lifting, but they seem stuck together. The manual says to use an air hammer, or heat to help separate the two, but I am reluctant to do so, as I don't want to crack anything.
Could I be missing some hidden bolts? I've had the lower unit off before, so I know the drive shaft slips out easily enough. I'm wondering if I've missed some bolts.
If it comes to it, and I have to use an air hammer, where do I use it? Manual says on the 6 studs that join the power head to the lower unit. How can I ensure I don't damage anything?
You have my deepest thanks, as always.
