Sidhewynder
- Joined
- Dec 15, 2010
- 17
Hi.. Need a bit of help with two items.
1) Johnson Serial Number J140TLCIM. Can anyone decipher the sequence? I think its an '81 140HP Electric Tilt Longshaft? I can't find what the "M" might be.
2) a) The motor has electric tilt which won't go down. The electric motor hums, but won't lower. How do you check/add Hydraulic fluid to these units? I didn't see a reservoir anywhere. There is a screw in the middle of hydraulic cylinder, which if it was higher on the cylinder I could see it as an add/check hole. Is that what it really is? Anything else to check?
