steam_mill
- Joined
- Jan 16, 2002
- 413
History:
I had a 12 foot short shaft aluminum boat. Had a 2004 2 stroke 9.9 merc on it. Transom measured 15 inches. Motor measured 20 inches from cavitation plate to just below the cowl. So, this should be a long shaft motor? Can you confirm?
So, my problem is, I bought a 12 foot smokercraft alaskan. 20 inch transom.
Put my 9.9 on it. Well, my prop slips a lot, can't make turns.
Basically, boat is unusable. Moved weight around in boat. Helped a little, not much.
I'm not able to make turns, prop slips and I come off plane.
Motor is running fine. Only happens on this boat.
Cavitation plate is 2 inches above bottom of boat.
So, is my shaft length wrong?
If not, can I fix this with a prop???
I'm very disapointed...
HELP!
HELP!
