Service Manual for a Mercruiser 350 MAG MPI DTS and Bravo 3 leg
ianf
Hi,
I was looking for a service manual for my 350
Details are:
Engine model MCM350 MAG MPI
Model No. 43500026T
Engine S/N 1A058922
Trans S/N 1A130441
Drive Type Bravo III
Drive S/N OW949504
Final Ratio 2.2
Control Smartcraft DTS
I have been looking throughout the other posts and found the link
http://www.4shared.com/dir/8iGasxP0/sharing.html
I have downloaded manuals #28 and #31 but these both have dates well before the date of manufacture in 2008
Also, I can't match my serial numbers to the "models covered by this manual" page
Do I need newer manuals?
If so, do you know where I can find them?
Thanks for your help
Don S
Re: Service Manual for a Mercruiser 350 MAG MPI DTS and Bravo 3 leg
Problem is, anything after about 2007, we have little or no information on. Not even a way of finding out which manuals you need.
I do have a 2008 index here http://www.4shared.com/document/8185WtK3/2008_Mercruiser_service_manual.html
Not sure if it will help, I don't even have a way of finding information about your serial number, Hopefully, someone with access to the dealer program can tell us which service manuals you need.
Fun Times
Yes you would still need service manual #31, But you will need to find and buy the latest version of service manual #31 for your engine.
Service manual #31 has been updated since then and most likely it is not out for free download on the internet yet, As a matter of fact even a mercruiser dealer would have a hard time buying one for you right now as they are showing the manual is out of stock till around 3/17/2011.
The latest part number from mercruiser for the newer version of service manual #31 is going to be Part number 90-864260T00.
Also Mercruiser has now merged Service manual #37 into Service manual #31, (#37 NLA ? Dry Joint Exhaust System (merged into SM 31 August 2009).
Also your Mercruiser drive service manual part number is going to be 90-865612T02 - #39 SERVICE MANUAL BRAVO STERNDRIVES
ianf
Hi Don S and Boat Tech,
Many thanks for your assistance.
Sounds like I might have to spend a few $ for the newer versions when available but in the meantime the older ones have helped a lot
Regards
