service manuals
Hello, im trying to find a place that would sell a service manual for a 1979 mercruiser 305. any suggestions?! thanks!!
thumpar
Look in the adults only thread. It has online versions of the manuals.
alright. im going to sound like an idiot, but thats ok. im a rookie to boating here, but i can not find the serial number on my engine. its a 305 that i know, but i cant find where the plate/serial number is. also the serial numbers on the drive system are wore off. the decal is party missing so i cant see what they say. any help is appreciated for a rookie like me. thanks!
i have read the "adult only" information on the serial numbers and what not but that didnt help. there is no plate above the starter on my engine. the only numbers i can make out any where is one on top of the engine- 6269797 gm and on the port side on the casing - 14040202 i am completely stumped.
Fun Times
For the casting numbers, are you sure the last number is a 2 and not a 5? On a few websites the only number that was close to yours ends in a 5. Do you believe the engine to be original?
This website looks helpful.
http://www.73-87.com/chevy_ids/sbcid2.htm
Between the website and the Mercruiser service bulletin linked below, you could also check your Block Suffix Codes:
[SIZE=-1]The suffix numbers are located on the pad in front of the passenger head, at the mating surface between the head and the block. If your block has been decked to help raise the compression or just to true up the head mounting surface, the numbers may have been removed during the process.[/SIZE]
http://www.google.com/url?sa=t&rct=...vnYjLYIojYw8E8HP2rAF56Q&bvm=bv.71778758,d.cGU
Here's a helpful service manual look up chart for you, http://www.scribd.com/doc/136181601/2008-Mercruiser-Service-Manual-Index
[SIZE=-1]1979-82[/SIZE][SIZE=-1]14040205[/SIZE][SIZE=-1]267[/SIZE]
yeah i looked again and it was a 2. im thinking that the engine is not original but that makes my situation worse.
