Dallas214Stars
- Joined
- Apr 5, 2020
- 62
So after very troubling day at the lake and
a compression test cylinders two and three dropping to 60 and 30 psi I’ve decided to change the head gasket on my Chrysler 115 hp. I’ve been reading that the bolts need to be torqued correctly… And I’m not sure how much they need to be torqued, does anyone know the process of this and how much? Also I’m reading the reason the head gasket could’ve blown could’ve been 1- that it’s old and just failed, 2- that impellers bad so I’m going to check the water pump and replace it if necessary, 3- thermostat went bad. I’m trying to figure out what kind of thermostat does this motor take, and where can I get a new one? Any other ideas of what I might need to check while replacing the gasket would be great. Thanks for all the help
