Set Spark Plug Gap? for 1977 Rude 115hp
Joe Reeves
Re: Set Spark Plug Gap? for 1977 Rude 115hp
1977 115hp Evinrude..... Champion QL77JC4 or L77JC4 s/plugs. Set the gap at .040 .
Justin Sims
Joe,<br />Thanks for the info.<br />What does the 28 degree Spark Advance sticker mean?
Joe Reeves
Sims.... Look at the timer base under the flywheel. As you advance the throttle, the timer base moves towards the full spark advance stop screw (the one with the black rubber bumper). When the engine is running at the full spark advance setting, you should obtain a reading of 28° when aiming a timing light at the timing pointer and the flywheel markings.
