stevehendo34
- Joined
- Aug 7, 2010
- 92
I saw how to do this on youtube statically.
Set primary pickup idle advance
Setting spark advance screw
The rest for my notes:
Set secondary pickup in back of distributor that's turns top portion of distributor?secondary pickup:
Pull on distributor arm aft
Set screw when its all the way aft + a bit more to let throttles open up completely.
- Remove idle stop plate
- Remove spark plug # 1 put it by ground
- Set to timing mark ATDC 5 degrees
- Twist distributor cap bank and forth
- Listen or watch for spark on # 1
- Look for black arm on distributor to just touch carb butterfly arm
- If no loosen distributor screws on top and twist and adjust until # 5 true
- re-install idle stop plate.
- Set to timing mark ATDC 20 degrees
- When here or see spark set advance screw there
- Rotate distributor back
- When the base of the distributor stops set screw at that point.
