Setting Float 1999 25hp WMC Carb....
dfwbmw
The book says this is how to set the float. Seloc Manual..... "With the carb in the position Shown, the distance from the lower edge of the float and the top of the retainer, should be 1 inch" First off this don't have a picture it is missing. I assume the "lower edge of the float" is the side you can now see with the carb upside down. What is the "retainer" that I need to messure against. Is that the body of the carb? If so there is a ring on the inner side that one hiegth, gasket ring another distance, and outer body that would be another. Thank in advance for any help. I thought maybe the merc full repair kit would have instructions.
dfwbmw
Re: Setting Float 1999 25hp WMC Carb....
Well I gave you guys a chance and then i ran down to bass pro dealer and asked the mechanice down there. Even in the Mercury manuals they do not show you a picture. They don't want the liablility. But they told me how to get it right and how to measure it properly. Thanks again.
