setting fuel air mixture 3.0L
droptheline
Detonation is the problem this year, have set my timing and got my octane up to par, put vents on my dog house and added another blower, going out to test tommorow and was wondering how one goes about calibrating their fuel/air intake setting correctly. any help is better than none at all. thanks
89 3.0L
Re: setting fuel air mixture 3.0L
Ayuh,... It's all covered quite clearly in the Manual, which can be downloaded from the Adults Only section of this forum....
Have you Rebuilt or replaced the Carb,..??
I suspect the Hi-speed circuit is fowled,... A Lean condition will cause Detonation...
Those screws only control Idle...
Ayuh,... I guess I missed that bird, Didn't I,..?? Fouled.....
