Sunken Ship
- Joined
- Jun 19, 2014
- 252
I made a shunt out of a plug I had from an old project, but I am doing something wrong. Steps that I took:
1. I hooked the shunt up to the distributor (not battery) while engine was off;
2. Connected timing light with clamp on no.1 plug wire (P-side front cylinder);
3. I started the engine;
4. With engine running I connected the shunt to the battery (didn't notice much of a difference in RPM change when power was connected); and
5 Attempted to adjust the distributor while the engine was running.
The timing mark on the crank pulley was right around the 3 o'clock position when the light flashes on the light while timing notch on the distributor cover is around the 1:30 position (approximately). I turned the distributor counter clockwise, but by the time I got the mark near the notch on the timing chain cover the engine would die and would not start since the engine was so far out of time. I did not even try rotating the distributor clockwise to try and get the timing correct. I figured by the time I got the mark from the 3 o'clock position on the crank pulley all the way around to 1:30 on the timing cover, it would be so far advanced it would never run right.
Any ideas what I am doing wrong? Maybe the shunt is not working? Engine runs great with the timing mark right around the 3 o'clock position. Just afraid of detonation if I am off. Appreciate any help/suggestions.
Thanks
Thanks
