Engine is a 94 Mercruiser 305 Chevy with a Edelbrock 1409 Carb and Alpha 1 Gen 2 drive with 1.65 Gears.
I was having a slight bog after my 4bbl upgrade only on Take off, so I was told to check/advance the timing.
Well I finally got a chance to get in the boat last night on the trailer and check the timing. It seems that it was quite advanced. What I found is that it was set to about 14 degrees BTDC, I am guessing this as the marks only go up to 12 degrees. I turned it down to about 12 degrees and it seemed to sound a little more powerful on the trailer.
Would it being set this advanced have caused a slight bog on take off? It would only bog down for a second or split second when I nailed the throttle from sitting still. If I was idling around in Gear at a little over or at 1000 rpms it would not bog as bad, but would just go. I talked to Edelbrock and got some hints from them, but they told me to check the timing and advance it some, but its already way advanced.
Any ideas?
And this is not the version, from what the Merc Manual states to ground the wire out on, as stated in these excerpts from the Manual.
This is whats stated for the Thunderbolt V
Thanks,
Bryan
Any ideas?
Thunderbolt IV Ignition
Timing
1. Connect timing light (91-99379 or similar) to No.
1 spark plug. Connect power supply leads on
light to 12 volt battery. Refer to ?Specifications?
for cylinder numbering and location.
2. Connect tachometer to engine.
3. Start engine and run at normal idle speed.
4. Aim timing light at timing tab, located on timing
gear cover and crankshaft torsional damper.
IMPORTANT: GM engine timing marks (on tab)
are in 2-degree increments. MCM and MIE LH engines
will have ?A? (Advance) mark to the left of
?0.? Timing must be set on the ?A? side of ?0?
(Top Dead Center).
5. Adjust timing by loosening distributor clamp and
rotating distributor body as required until timing
mark on damper or pulley lines up with the mark
on tab specified in ?Specifications.? Tighten
clamp and recheck location of timing mark.
6. Stop engine and remove timing light.
Timing and Idle Adjustment Procedures For Thunderbolt V Ignition
Setting Base Ignition Timing
1. Connect timing light to number 1 spark plug.
Connect timing light power supply leads (if
applicable) to 12 volt source.
2. Connect a shop tachometer to engine.
3. Using a jumper wire, connect the ignition system
timing lead ?13? (PUR/WHT wire) to a good engine
ground (?). This locks the ignition module
into the ?Base Timing Mode?.
4. Start engine and run at normal idle speed. Allow
engine to reach normal operating temperature.
5. Aim timing light at timing tab, located on the timing
6. Adjust timing using the conventional method.
IMPORTANT: Be sure to disconnect the jumper
wire from the ignition system test terminal before
attempting to resume normal operations. If the
jumper wire is left in place, the ignition module
will operate in the ?Base Timing Mode?. This
means that the additional timing advance features
would not function.
7. Make sure that the distributor has been tightened.
Remove the jumper wire from the timing
terminal.
8. Stop engine and remove timing light.
Adjusting Idle Mixture
The procedure for adjusting carburetor idle mixture
can be found in the appropriate engine service manual.
This procedure also requires that the ignition module
be locked in the ?Base Timing Mode?.
IMPORTANT: In order to properly set idle mixture,
the ignition module MUST BE locked in the ?Base
Timing Mode?. This is necessary because of the
?Idle Speed Control? feature that exists in the
ignition module. See information on the previous
pages about this feature.
1. Using a jumper wire, connect the ignition system
2. Adjust idle mixture following the procedure in the
3. Remove the jumper wire from the timing terminal.
Adjusting Engine Idle Speed
This procedure should be done with boat in the water,
drive unit in neutral and engine at normal operating
temperature. Refer to the Operation and Maintenance
Manual for the correct idle speed.
1. Disconnect the throttle cable from carburetor.
IMPORTANT: In order to properly set idle speed,
4. Start engine and allow it to reach normal operating
temperature.
5. Adjust idle speed to recommended RPM.
6. Stop engine. Readjust cable barrel and reinstall
the throttle.
would not be functioning.
7. Remove the jumper wire from the timing terminal.
Thanks,
Bryan
