justinteoc
- Joined
- Jul 24, 2013
- 51
Ok so first my engine is a 97 3.0GSMLKD and I purchased a new carb it is a holley 2bbl and It has a dead spot in it but I'm thinking it has st to do with the timing because if you advance the timing while at around 1100rpms the engine runs excellent at cruising Speer and wot but if you,return to,idle it runs like crap but when you return timing to 0 it idles fine but when accelerating it pings, knocks and has a dead spot when accelerating. I'm thinking that whatever advances the timing is not working.. How does the timing advance on this engine? Note that my timing specs are done by ear my timing light got run over and I have not replaced it yet ha.
Second question I can not find a FACTORY service manual anywhere. There is not a volvo penta dealer within 200 miles from here does anyone know where I can find one? Is clymer or seloc equilivant?
Also when I uncovered my boat this year I noticed the oil was a little milky we'll I drained the oil and there was NOT ANY WATER that come out first. So I changed it and I ran it about 2 hours yesterday and the water did not return so my question is can this happen from it being in this southern climate all winter without being run? When I winterized it I filled the block with a 50/50 antifreeze and DCA4 corrosion inhibitor mix so I KNOW it didn't freeze? But looking at the edges of the head gasket it looks pretty rough (this boat use to run in salt water). Are the head gaskets on this 3.0 engine bad about going bad? It has a brand new intake/exhaust manifold.
Thanks in advance for the help you guys on here are my only means of troubleshooting the only boat shop around here... We'll lets just say they specialize in..........drinking beer and smoking dope... Ha
I have one more question the only way you can get ethanol free gas around her is 87 octane. Would it be better to use 93 octane with 10% ethanol and use a ethanol treatment or is it better to stick with ethanol free gas?
