1960 Starflite
- Joined
- Jun 23, 2011
- 390
1979 Century, 19 Ft, 140 HP Mercuriser I/O
I did a search on this fourm for an answer, found a couple old threads, but they never finished the discussion. Would be nice if people reported how/if they solved their problems.
As long as I leave the trim completely down the boat will steer without a problem. As I start to raise the trim, after the boat planes, I get severe torque steer to port. It is so bad that I must keep both hands on the wheel or it will turn a quick circle to the left. I really can't say just when this started, but it use to go straight when it was trimmed up.
I've moved the trim tab (trailering edge to port) as far as it will go. I even ground additional clearence on the tab stop (upper side) to move it even futher.
I changed from a 3 blade, 14 1/2" x 19 pitch prop to a 4 blade 14 1/2" x 17 pitch prop thinking it would help, It didn't. The engine operates at 4400 rpm with both props, right where it should be.
The drive has a whale tail on it, been there for years. The skag isn't broken or bent. I don't see any visible problem with the hull. I just put the boat in the lake, where it stays all summer, in the boathouse. It is always stored in my garage for the winter months.
I need help, please !!
Tom
Tom
