So, I recently bought a boat and the guy told me that the overboard pump (I think it's referred to as the macerator pump?) doesn't work. When you turn it on, it just trips off (its on its own breaker). He said he never bothered to replace it because you can't discharge overboard - and showed me the placard in the bilge that says you cannot discharge within 3 miles of land.
I've been doing a lot of googling, and I want to fix the issue (wife wants to be able to use the bathroom while we're on the lake, I'm sure someone here can relate..)
I've having trouble identifying what kind of system I have. I have an installed toilet, and the gray water tank is in the bilge just forward of my fuel tank (seems to be fairly good sized). 3 hoses that I can see on the tank, 2 on the stbd side, probably going to the head, and 1 on the port side which I assume heads to the aft bilge to the overboard valve and the pumpout connection.
Ideally, I want to be able to pump the tank overboard. Can anybody help?
Boat is a 1995 Regal 256 Commodore, 7.4L Merc with a Bravo 3
