larryengel
- Joined
- May 30, 2005
- 4
What shaft length outboard should I get for a 14' SeaSwirl (early 60s) that has a transom height of 17-3/4"? It seems like a tweener between short and long shaft.
Originally posted by JB:<br /> Hi, Larry.<br /><br />I suspect that you measured the surface of the transom and that it is "tilted" in at the bottom.<br /><br />Measure again, only measure straight down from the top of the transom, perpendicular to the bottom. That should give you a measurement a lot closer to 15", which is the shaft length I would use.<br /><br />Good luck.![]()
