Re: Shaft length for inflateable boat
Spyke;<br /><br />First of all i do not think that the transom delamination was the cause of the Hydrofoil. Just get a good Hypalon Glue and clean everything really well, then re-glue, or take it to an inflatable repair facility. Call the manufacturer for a list of repair places.<br /><br />Next; when the motor shaft is too long the prop has excessive leverage. The shaft and the prop are pushing from a position well below the bottom of the boat and trying to lift the bow. The best place for the prop is as close to the center of the boat as possible. Up - down and side to side.<br />If you draw it on paper you will see what I mean.<br /><br />The hydrofoil will not provide enough stern lift to truly affect the bow rise. It is simply to small in surface area. <br /><br />Infaltables and Ribs are light and the weight balance is very far to the stern. They also have a small foot print in the water for the amount of load they are expecte to carry. Therefore it is harder for them to plane and stay on plane (PSI is high). The more surface are you can add to the hull (ie: trim tabs) the easier it is to plane, especially if that surface are can be adjusted to go up and down as needed (like plaps on an airplane wing. The deployed angle of the trim tabs during acceleration provides aggressive lift at slow speeds, then when on plane they come up to horizontal and lift without adding drag.<br /><br />Smart Tabs are automatic and now used by a number of Rib manufacturers, law enforcement, and the military because they make these boats more efficient. <br /><br />One last thing regarding hydrofoils. The technowlogy is not new and is usefull, but needs to be integrated int the design of the boat. Not to mention that you never want to lift the boat from the motor (center of the boat). The boat should be lifted from the hull.<br /><br />If you would like a copy of a tech report on boat ballance and performance send your address to
John@nauticusinc.com. There is no charge for the report. To is free to anyone!
