I'm looking for some input on putting a kicker motor on my boat for shallow water operation. I live on a mile long tidal creek that ranges from 4' at high tide to 18" at low tide. My boat is a 20' tri-hull that drafts about 13" so it's possible to float the boat, with the O/B up, even at most low tides. My problem is that when I lower my motor down far enough to keep the water inlet submerged but not so low as to hit bottom, the prop is angeled about 15 or 20degs towards the bottom which causes it to suck up mud off the bottom and clog my cooling system. So i was hoping for some input on using a smaller kicker motor that would be mounted such that, when I put it in the water, it would be protected behind the transom and perpindicular(sp) to the bottom.
