Got her started! But still gotta few questions.
There is a little lever by the larger REV-N-FWD lever.(The Larger one appears to be the throttle)
The little lever says START at the top and RUN at the bottom.
I push the little lever to START and turn the key while the big lever is in "N" and it fires up. I wait about a minute and move the little lever to RUN and the motor dies.
However, If I do the same steps but push the larger lever towards FWD a little so it runs faster then move the little lever to run it will stay running, but when I move the large lever back to "N" while the little lever is still on RUN the motor dies.
What could be wrong?
And yes..I used my muffs while running it! o
Thanks!
Carl
Thanks!
Carl
