Forgive me for I am new to boating and don't know technical names for parts.
I just got a 1968 Sportcraft which has a 168hp Mericruiser I/O for free. The hydraulic pistons which raise and lower the outdrive were off when I took possesion of the boat and now that I look closer I know why. One of the bottom bolts that holds the piston on has bee sheared off and I am not sure how to fix it.
I did not take a picture which I probably should so I will try and explain the part I am talking about. It looks like one long threaded bolt that holds both pistons in place. It passes through two verticle guides which I think support the outdrive when it is down. It appears to have three spacers OR be one thick solid bar that runs throught the verticle supports.
Kinda like this:
The far left is sheared off so it now looks like
Can anyone give me tip on how to fix this? I am not sure how to remove the exisiting bolt and replace it. Is it even replaceable? If it is not replaceable I was thinking about cutting more off the left side and have a welder put another piece on.
Kinda like this:
