I have a '92 evirude 120 and i was attempting to remove the bottom unit. I gently turned the screw retaining the shift rod to get it off, and the head popped off--I think the previous owner over torqued it when installing it. The question is, is there enough room between the set screw and the shift rod to get a dremel cut off wheel in there without doing too much damage to the shift rod or the retaining fixture?
