lostinthewoods
- Joined
- May 5, 2003
- 15
Well guys, thanks for the help with the screw stuck beside the porp shaft. As several have noted the impact screw driver is a awsome tool! You would really be suprised at how fast it'll twist the head right off
of that stubburn screw that's been causing you all that greif! <br /><br />Now the only problem is that the screw is now,,,,,,,,,,,,,well, um,,,,,,,,,,,,,, broken! I smacked the impact about 3 times and that was it. Looking at the screw shaft there is a spot just under the head that almost looks like the screw was corroded so baddly that it just popped. Now for the new problem at hand, the screw left in the hole. The screw shaft is so corroded that the cover plate behind the prop (the one I was removing the screw to get off) will still not budge. As the screw has corroded up the hole and will not break loose. Any suggestions?
<br /><br />Here is what I was thinking, maybe drill and tap the existing hole for a new screw? Will I hurt anything by trying to pry off the plate? (I don't like this idea as I'm affraid that the cover plate might bend in the process) <br /><br />Thanks again for the help,<br />Lost
