Re: shift at max.
I suggest you Find Another Mechanic.............<br /><br />If the Adjustment is Maxed Out, <br />My 1st Guess is that the Cables are Stretched out.......<br />The Lower Shift Cable is usually the first 1 to Go......<br />The upper remote cables will sometimes last the Life of the boat....... <br />Lowers only last 5 to 7 years, at Best, in My experince..........<br />
Question-could this be a potentially a big and expensive job?
Ayah......<br />And it'll get Bigger,+ More Expensive the Longer you let it Go..............<br /><br />Worn Gears have Nothing to do with the Shift Cable Adjustment........<br />But, <br />Bad Cables will Cause Broken Gears in a Hurry.....................
