Shift by hand??
Smig
Hey folks,<br />I'm helping out with the lower unit on an '89 40 HP Evinrude (E40ELCEC.) With the lower unit off, should I be able to shift into forward or reverse by pushing/pulling on the shift rod? If so, should it be easy or hard?<br /><br />Thanks<br />Shaun
rickdb1boat
Re: Shift by hand??
Yes, it should be easy if you rotate the prop at the same time...
Smig
Re: Shift by hand??
I can rotate the prop shaft without any trouble, but the shift rod will barely move and I can't get forward or reverse to engage. Any thoughts on what would jam up the shift rod?<br /><br />Thank you<br />Shaun
OBJ
Re: Shift by hand??
There would be a certain amount of push you need to get it in gear. The lower shift lever is held in place by a detent. Might have to push/pull the shift rod some force to get it to shift. <br /><br />What's the gear lube look like? Why are you dropping the lower unit? Problem?
rickdb1boat
Re: Shift by hand??
Yeah, OBJ is right. Not fingerlight... It will take a little push/pull force, but not something you should have to struggle with...
Smig
Re: Shift by hand??
Why it's dropped is a soap opera involving a blown lower, a lousy, unreliable mobile mechanic and a sister-in-law. The mechanic dropped the lower unit, took apart the midsection (I have no idea why he did that) and then left it all in a big box in his mother's garage! So I am helping my sister-in-law get it back together. She bought a used lower to replace the blown one and in looking it over I couldn't get it into gear. So is there anything that could jam the shift mechanism?<br /><br />I checked the gear lube and it looks great. I also thought I would replace the water pump while the lower is down.<br /><br />Thanks<br />Shaun
OBJ
Re: Shift by hand??
Smig....not always a good thing to do but, take a short piece of wood and put it on the top of the shift rod, smack the top of the wood with your fist or a rubber mallet....not a full 1 wood backstroke...just enough to move it. The stiffness isn't noticable when shifting from the control because of the leverage involved. Just a short tap should move it. <br /><br />If it don't want to move....can be anybodys guess why it won't shift. Anything from rusted up gears to damaged clutch dog.
ob
Re: Shift by hand??
Also confirm that you are indeed rotating the prop while trying to shift.
Smig
Re: Shift by hand??
Got it!! I finally found a good way to brace two hands while pulling up, there was a small movement and then as I rotated the prop shaft and pushed down it went all the way into gear.<br /><br />rickdb1boat, OBJ & ob - Thank you
OBJ
Re: Shift by hand??
Good to hear Smig..... :) While it's in gear, turn the drive shaft clockwise and make sure the prop shaft turns also. Hope the rest of the job goes well.
rickdb1boat
Re: Shift by hand??
That's good news, Smig :) Hopefully the rest of the job will fall into place and all will be well.......
Smig
Re: Shift by hand??
Thanks guys - I did spin the shaft in both directions in both forward and reverse. While I am doing that, is there anything that I should be listening or feeling for?<br /><br />Thanks
