shift cable adjustment
Slick89
last week i had ratcheting in my prop and was told its a cable adjustment, does anyone have info on this on how to perform this
Bt Doctur
If it worked correctly previously over time cables go bad.There are many reasons for ratcheting so start with the simplest, pull drive and inspect the shift components. In fwd it could be a simple adjustment ,in rev it could be corrosion in the shift slide and no adjustment can correct this condition
worst the cable is bad and needs replacing
ROY WILLIAMS
the mechanic boat is the shift cables and the switch ..
also the shift cables of the YOUTUBE ..
flashback
Prop will ratchet in the opposite direction of the chosen gear.. it's normal..
