I need a bit more help. I just got the outdrive together and on the boat after replacing the clutch and reverse gear on an 86 OMC stringer 4.3L. The drive shifts fine into forward, neutral and reverse when pulling the wires from the cable by hand. When I install the wires on the shift converter it will shift to reverse, and neutral. But when I push the converter all the way forward the pendulum bottoms out on the converter housing befor it engages. Its almost like the forward wire is to long, and needs to be an inch shorter to give it more travel inside the housing for it to engage. What could this be and what can I do to solve this? Is there some sort of adjustment? I have pulled the cable tight and there is no slack in the converter.
I havent had much luck with any replies to my posts lately, I am really hopeing someone can help me on this.
Thanks
Thanks
