I'm working on my Alpha 1 Gen 2 shift cable. I got the special tool to remove the cable end guide in the bell housing. The tool (Mallory) promptly broke with almost no torque at all, so I chased around for a day and found some one to weld it back together. Then the brass nut seemed to break free with only moderate torque, 3/8 breaker bar, one hand, no biggie.... Looking good....
BUT the cable spins as I turn the brass nut. Maybe this is supposed to happen, but no one mentions it. After pondering it I decided it doesn't matter because the whole cable jacket spins inside the boat so that fitting should still unscrew and back out, Right?
Wrong.
the end fitting is now showing about two threads backed out and it just spins and spins, (spinning the cable jacket inside the boat with it.) It will not back out any further. I can't get to it easily to seriously yank on it, but pushing on the cable from forward of the bell housing (between the bell housing and transom by the shift cable bellows) does nothing. Pulling on it with what force I can from astern does nothing, though I haven't tried destructive force with vice grips on the plastic tube sort of thing yet. I tried to slip a screw driver behind it a bit so that it would catch the threads as I turned the nut. No dice.
It is as if there is a non-captured nut behind the bell housing that I can't see that wants to be held by another wrench , but I don't think there is supposed to be anything there. Alpha 1 Gen 2, I've never seen any reference to that sort of thing.
So I figured maybe I sheared off the brass fitting inside the threaded hole. It sort of looks like that might be the case, but it is hard to see in that deep hole..... but if that is the case how come the broken off outer end doesn't just fall out in my hand and leave the rest stuck in the threads?
So I'm feeling pretty stupid at this juncture. It seems like it should either just come apart properly, or if its broken just fall apart. I can't see what is hanging me up.
What is the next step? If it is broken how do I fix it? Cut the cable jacket behind the bell housing and get the whole thing on my bench and maybe drill the old fitting out and re-tap the hole?
Grrrrr....
Thanks,
Peter
Wrong.
Grrrrr....
Thanks,
Peter
