1984 Alpha One, 3.0 Liter Mercruiser
I cannot get into reverse. The OD is off and I can see the cable in the housing bottoming out in neutral so I know that is why I cannot get into reverse.
The OD shift cable moves freely from forward to reverse.
The travel of the cable from the shifter appears to be too large. If I put it in forward the OD shift cable is fully extended outwards. As I approach Neutral the OD shift cable gets bottomed out.
If I remove the upper cable on the engine and then put the shifter into reverse the length of the cable extended appears to be too long for mounting. I have followed the directions in the manual for aligning the cables but I still have the same problem.
Also, when I stored the boat for the winter the problem was not there. I did not remove the OD for winter storage. I did remove the OD this spring because I replaced the transom and I noticed the problem then before I pulled the OD.
Any Advice??
Any Advice??
