Twin 1993 200hp Johnson Ocean runners.
Well I broke my #1 rule of boating, I let someone borrow my boat. Now it is broken.
I think it is a stretched shift cable but Id like a few other opinions before I go switching parts out
The bolt that holds the adjuster on the engine was loose so I tightened it up. The motor shifted into forward fine but wouldnt go into reverse. When I adjusted it to more to the reverse I lost forward but I could engage reverse. I played with it a bit and until I reached a point where I could not get it into forward or reverse. So I figured that I didnt have enough throw in either direction Stretched shift cable??
I adjusted it back to where forward would engage and put the and put the boat away.
I have always had trouble with getting any JohnyRude to shift properly. Every 80s-90s Johnson I have ever run wont go back in to N without the Johnson Jiggle, where when you pull out of gear you have to wiggle it in N to get it out of gear.
Does anyone have any tips or thoughts?
