Shift Cable Slide set screw
jimrockireland
1983 MCM228 engine (serial#6285627) with sterndrive serial# 6289715. I am replacing my shift cable bellows and in trying to get the set screw on the shift slide off it broke. How do I proceed from here. I was hoping to re-use the shift slide and shift cable but I'm guessing the slide will also need replacing at this point.
Alumarine
I think for $9 it might be worth getting a new one 33981T 1
It might cost that much for drill bits.
Bt Doctur
if it is the small black setscrew in the aft side of the slide, there is no reason to remove it. The core will come out with the slide attached
jimrockireland
My real question is how to disconnect the shift slide from the shift cable without destroying the shift cable. If I drill out the set screw will I destroy the cable or should I just try and crush the shift slide and disconnect the shift cable that way?
