timharper89
- Joined
- Jun 24, 2018
- 277
Trying to replace my shift cable in my alpha one gen 1 4.3L. Following this video https://youtu.be/PZN-HHuIDPI, I got to the part where you pull the shift cable put of the sheath from the transom side. I removed/disconnected everything up top (upper and lower disconnected, lower shift cable end removed, removed "jam nut" and "threaded shaft"). Next step is to remove the cable from the sheath. Mine won't come out. It's there something I'm missing? It moves about 3" and stops. Do I need to somehow take the silver piece (pictured) off first? Also attached a picture of the lower shift cable from the engine compartment. Thanks for the help
