CAPTKEV85
- Joined
- Mar 12, 2008
- 229
Well yesterday I replaced my shift cable because I was stick in forward. Pulled it out of the boat and the entire cable was melted. The previous owner had it done last year and it looked like it was resting on the y pipe. So i put a new cable in and boy is it smooth. Now I have been running hot at idle but fine at upper rpms. So I split the drive and installed new water pump. Also cleaned out water intake which was loaded with growth. Put it in the water and she is running alittle cooler but still gets hot at an idle. Could this be the engine water pump? New thermostat was installed a month ago. Also drive was milky, now signs of leaks anywere and the lower was rebuilt last year.
