I have a 1994 Chris Craft Concept with a 5.litre OMC(Ford) and Cobra Outdrive. I am having a problem with the Shift Control System. The problem is when I shift from forward back into neutral the outdrive is still engaged in forward gear. I have followed all of the directions in the Cobra Service Manual (the factory manual). I have adjusted the Center shift stroke. I have adjusted the the linkage all the way out but it still doesn't seem to want to disengage into neutral. Here is the rally strange thing, when I do pull the shift lever back to the neutral detent position and then shut off the engine, I restart the engine back up the stern drive comes back up in neutral? Very strange. Any ideas would be greatly appreciated!
