Shift cutout switch
smithrock
Mercruiser Alpha 1 Gen 1
I just installed a new lower shift cable, got it adjusted properly and it's shifting fine now. my question is: with the new cable installed, my cutout switch really doesn't even move when shifting, is that normal, or should it have noticable movement when shifting?
searay3
Re: Shift cutout switch
Won't see it operate untill there is a load on the prop. Drop it in the water and you will see the movement. Probably will need to do that anyway to get it adjusted properly.
smithrock
Ok so there should defintely be movement on it, when there is a load on it?
