Caveman Charlie
- Joined
- Oct 31, 2007
- 545
I'm converting my breaker point ignition over to Pertronx HEI on my 73 Silverline I/O with mercrusier 140. One wire from the negative- side of the coil goes to the points. But, There are two extra wires coming off the negative - side of the coil. One goes the the tachometer. No problem there. But, the other one (according the the wiring diagram) runs to a shift interlock and then to a ground. What does this shift interlock do? Should I just leave it hooked up? Or, would it be best to unhook it now that I'm running a new 12 volt positive wire from the ignition switch back to the positive + side of the coil.
(This is not a neutral safety switch. That is in a different place.)
