Since I bought the boat last year I've had a lot of difficulty getting it out of gear and back to neutral when on the water. I thought it was the shift cable as I began having trouble getting INTO gear this year. However after replacing the shift cable and doing some research I learned it is my interrupt switch. After inspection, the roller isn't even close to being seated where it is supposed to be. The rocker is sitting well above the roller and I'm not sure if it can be adjusted to line up right. I can pull the switch arm back and get it on the bottom part of the rocker (which doesnt help obviously), but not in the center. Any advice on getting this lined up correctly?
Also the switch doesn't appear to work. With the motor running, I've pushed that plunger in a good ways and the motor doesn't stall out or even hesitate. That will be my second priority
Here are some pics of what I'm talking about. https://goo.gl/photos/WjwH2GqaCj7FzEzJ7
Thanks!
(Also since I've discovered this was the problem, I have just been manually killing the motor when getting out of gear. Makes for a real fun loading experience
Thanks!
