Shift Interrupt Switch Problems
Maxum88
Hi Guys,
I read Don's post about how the shift interrupt switch works, but my question is, What can I do to test while it's on the trailer? I put a meter to it and figured I would get 12v to one side of the switch and I have nothing. I want to ensure I have everything figured out before I take it out on the water again.
I have an '88 Maxum 3.0L Mercruiser w/ a prealpha outdrive. When it's on the trailer & w the muffs on, I push in the "switch" and the motor doesn't die, which leads me to believe I'm not getting my power...but then again, the switch only works when in the water and the prop is under load. :confused:
Thanks!!!
MRS
Re: Shift Interrupt Switch Problems
Max, you are in the omc section need to go to the merc section. And welcome to iboats great place...
Maxum88
oops! Sorry...searched a problem similar to mine and just posted. Thanks!
