Re: Shift interrupter cable lubrication?
Disconnect the lower shift cable from the shifter plate. Have a helper turn the prop while you push and pull on the shifter cable. How does it feel? Tight? If so, the only solution is to change the whole cable assembly. Forget trying to lubricate it.
With the cable disconnected, put the helm in neutral. Is the shift interrupt switch located in the center of its travel?
