Guys,
I had an issue with ignition in my boat and I thought I had fixed it but its back again. And Now I have discovered something.
I have a 91 GM 3.0 4l Its outfitted with the OMC stuff and has the GM EST igntion
Anyways for some reason I have been beating my haed trying to figure out why the boat would not start. Seemed to try but would not start.
There are two plugs on the Dizzy. One for power and such and the other plug has two wires that you can clearly see go to the shift interrupter area. Funny thing. I unplugged that plug and engine fired right up. While running if I plug it back in engine stumbles badly.
My question is this. Can I run it like this? I know that rpms need to be low enough to shift. I get that. But does this being unplugged have any effect on timing? I have no idea whats going on. I checked both switches and there fine. I lowered RPMS down and shifted into forward and gave it some gas. Seemed to run fine and the shifter felt great of course. But is the engine running normal in this condition? I ask because I dont undertand the advance on this Dizzy and want to make sure I dont take it out on the water and have no power to get on a plain.
