shift issues
Pulled drive off 82 228(305) mercruser. to aline engine and replace impeller, and cant seem to get the shift cables adjusted to have reverse. I can manually shift drive to lock prop in reverse. And pull lower cable to lock in reverse. but I have to pull hard and if I let off tention it slips out. cable seems free and we have been over the linkage several times what exactly should I be looking for? its like I need a little more travel on the fork in the outdrive. even tried going a tooth off on the shift shaft in the lower. shifted to reverse fine but no forward...
Bt Doctur
Re: shift issues
Try trimming a 1/4 inch of the plastic guide tube, or remove the slide ,setscrew,remove the inner core and clean slide with a drill bit. sometimes crud get built up inside and prevents full travel for reverse.Otherwise replace the shift cable.Outside chance the shift spool is worn in the lower unit.
Re: shift issues
"plastic guide tube" ? the sheathing on cable? And it seems the Crud would limit forward (cable in at shift plate) rather than reverse or am I thinking the wrong part?
Bt Doctur
Re: shift issues
the plastic tube the shift slide goes over, crud can pack in the slide preventing full travel
Re: shift issues
Thanks! that makes more sence now, I am a mechanic by trade but dont have much boat experiance.
stonyloam
Re: shift issues
For reverse the cable does move forward (pulls the upper shift shaft arm, and turns shaft CCW).
