shift linkage alignment
derekv
I have a 1975 merc 650 and I cant seem to get the gears to work properly after reinstalling the lower unit. If I follow the manual I get forward where neutral should be and no reverse. I played with a couple different combinations of spline alighnment and could get only forward and neutral or neutral and reverse is there a trick to doing it or could something be worn out?
Chris1956
Re: shift linkage alignment
Elto, Put the lower unit into Neutral, and it should stay there. Shift the control into neutral and then install the LU.
derekv
I think I tryed about every combination possible but I will try it again with the shift cable acually attached. I'm wondering if there is to much slop between the upper and lower splines.
