Re: Shift linkage disconnect 86 225 Johnson
Dhadley, we put a piece of 2x4 between the power head ( minus cowling) and the engine transom bracket and prised the enginge up a few inches and the shift rod popped in no problem.Why do you say the lower mounts are the problem , it would seem to be the upper engine mounts are bad as the power head is where the movement is -please confirm. If I have to change the upper engine mounts can you tell me exactly where these are located, what they look like, how many there are ,cost and basic outlime of how they are changed and if there are any tricks to make easier or pitfalls to avoid. The manual does not seem to address this matter. I am going to run for a while like this but afraid of stripping the gears eventually<br />Thanks for your time.<br /><br />PS : you were right about towing out on the 30' Scarab even though Wellcraft told me to toe in.
