Shift Linkage Rubbed Bellow raw! 275A
Brucetafer
is this normal??? i just got off the lake and saw TONS of water coming out of the drive with a little bit of drive oil with it... i see holes from the shift linkage rubbed right through.... is that normal??? if it is thats horrible design....
is there a step by step guide to replace the upper bellow??? ive been searching for a while and cant find anything.. thanks!!
Don S
Re: Shift Linkage Rubbed Bellow raw! 275A
Yes, it's normal. Those bellows are thin to begin with, In salt water, I changed my bellows every other year. Just to prevent any kind of leak problems.
Changing the bellows is a simple job. Remove the upper gear box, replace the seals and bellows and your's set to go.
Here is the link to the Volvo section from the stickies at the top of the forum. Now you know why you should actually look at the stickies. They are there for a reason.
VP. - Page 1 - 357328
Brucetafer
cool thank you... ive looked in there, but was hoping there was a easier method then i found the picture you posted and the part numbers of the seals and orings to get... thanks again...
