Boobie Trap
- Joined
- Feb 21, 2011
- 122
Here is the setup:
Started engines, hosted the anchor, put both engines in gear and away we went. When I started increasing speed I heard one engine over revving more than the other. Port engine was not going in gear. Shut both engines down and placed them in gear. Tried to turn the STBD prop, locked, turn the Port prop, spun freely. Checked cable to both engines, could feel the cable moving on both engines. We go to marina on one engine.
Fix it tomorrow. Party time!
Thinking about the problem that night,
it is either linkage, drive shaft from engine to out drive OR the neutral button is stuck.
Upon return to the boat, I check the neutral button. It seems OK. I decide to look at the cable. I take off the cover, remove the four screws and pull the throttle quadrant out of the mount. I move the port throttle and then I see the problem. The clamp that holds the cable housing and prevents the whole cable from moving is loose.
A screw has backed out and now when the throttle is moved, everything moves accomplishing nothing! YAHOO!!!! Easy fix! I tighten the screw, check the other throttle cable and reassemble. Problem solved.
Thought I would put that out there for others who might have a similar problem!
