andrewgroup
- Joined
- Aug 23, 2003
- 115
1969 Mercrusier Type II..<br />This winter I drained the gear lube from the outdrive in the fall. Filled it with Amsoil 80-90 Marine Gearlube 5 Quarts, prior to waking it up from the winters sleep. Shifting into forward or reverse seems extremely metalish. Was fine in the fall. I thougth the amsoil marine gear lube seemed thinner that the old green quicksilver stuff, but can't believe this made for noise. I'm thinking the shift interupter mechanics are wrong since he small switch does kill the engine when depressed.<br /><br />Does anyone remember or still have any experience on the Older 1:78 type two outdrive? If so, what are your thoughts on the best gear lube for this drive?<br /><br />andy
